Maytag dryer runs about 30 minutes, gets loud, then cuts off.
My Maytag Dryer will run for about 30 minutes then it will get louder and then shut off. I can wait about 5 minutes then restart it. We go through the same process of running for 30 minutes the shutting off. We have taken the dryer apart and cleaned out every particle of lint. Do you know what could be causing this problem?
Most likely the motor overheating, thus shutting off. When it cools off after a few minutes, it will come back on. Motor would probably have to be replaced.
