Maytag Dryer Switch Problem
The timer switch is very iffy, must pull it out, jiggle it, press back in a few times before the dryer will start.
Any ideas? How hard and how $$$$ is it to replace the switch?
The cost for the part should be about $55 to $60 and the replacement is pretty easy. Just open up the console, remove the old and replace it with the new one.
There are several different timers for your model, so have your model number and serial number when you order the part.
