Maytag dryer wont run
Rollers were rumbling,so I ordered new ones, just before they got here the dryer wont run at all. door switch checks ok, tried turning off the breakers to try a reset, The timer display and lights work on the controls. All I get is a beep and I can hear a click when I press the start button.
Any ideas would be appreciated
Dennis
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=med9600sq0
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208563816.pdf
First things I would check is the thermal fuse on the blower and the belt switch both are in the motor circuit.
