Maytag dryer won't start
Had a brown out and my Maytag dryer (MEDB200VQ0) apparently is the only victim. It won’t start. Diagnostic tests reported "F01" followed by a "C0" and so I ordered a replacement control board (W10111621). Switched in the replacement board and it still won’t start. Diagnostic tests now only report "C0" which as far as the internet is concerned is an unknown code. Anyone else know how to proceed?
Did you check the thermal fuse (#41 at the [B]diagram[/B]), the belt and the door switch?
Belt and door switch are good. No continuity on the thermal fuse, so time to replace. Checked the Thermistor (#51 on diagram on the blower and it was in range. Should I also test the Thermal Cut-Off and Thrmst Fix (#47 and 48 on [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5518693&diagram_id=28616111)) ?
Hi.
Yes you may and if needed - replace them.
Thank you.
Simon.
