Maytag Electric Range Digital Display Blank
My Maytag model che9800 bcm range digital display has gone blank. It is a slide-in model (purchased April 1997), with the controls on the front end above the oven door. Pushing the keypad buttons does nothing. The cook-top burners and oven light works. The oven itself does not work. The circuit breaker for this outlet is not tripped. The oven element is intact (replaced 5 months ago). Is there an internal fuse for the control panel? If so where is it located? If not a fuse, is it a blown out circuit board? Would this be a difficult problem for me to repair? I’m experienced at soldering and replacing components on circuit boards. So, if were a bad capacitor I could replace it. Expensive? How do I access the control panel? I can’t see how the glass cook-top is removed. Can you give me a step by step troubleshooting procedure to follow?
Thanks, Ted-
My Maytag oven shut down while baking Christmas dinner. Gas burners and light still worked fine. After trying Sabbath fix (hold Clock button for 5 seconds), we called one of those guys who knows how to fix everything. His suggestion of unplugging it for one minute did the trick! Caution: my clock has been losing time lately, so this may not be the ultimate fix.
No it is not. The clock will go out again, because one of the relays on the board, are most likely heating up. Tom http://www.applianceeducator.com/parts.htm
