Maytag filling slowly
My Maytag washer fills very slowly; It seems that either something may be blocked, a pump is not working or a valves is partially open/closed. All cycles and other functions seem to be working fine. I am not familiar with washer operation so any info would be helpful so that I don’t replace the incorrect part.
If there is nothing wrong with the incoming water pressure then the problem could be a clogged screens (#8 on the [B]AP4026239 in the water inlet valve. Turn off the water to the washer and unscrew the fill hoses from the water valve. You can replace the two screens or the whole water valve. Replacing the whole valve will make the repair more reliable.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=855878&&model_id=42324
