noticed last night Freezer was warmer than normal and ice maker not making any ice. all contents were thawed. fridge above is working normal.
freezer makes buzzing sound with a click at the end every few minutes
— Begin quote from lshamim;118720
That is not a real good sign. If the noise you’re hearing is the compressor trying to start and the overload then kicking it off you may have a compressor problem. Depending on the age of the unit, you may want to get a hold of an authorized servicer, the compressor may still be under warranty.
how can I be certain if it’s the compressor? Is there something i can look at or see before i call a pro?
if it is the compressor - what’s the average cost of part and labor?
model number is MFD2560HES and serial is 10884272er
i realized that both the refrigerator and freezer are not cool enough. the fridge portion has also warmed up a bit since last night. HELP
— Begin quote from lshamim;118752
If the compressor isn’t running it will sure affect both sections. Have you done what I mentioned in my previous post?
Below is the part number for the compressor and price is $248.83. You’ll have to check with local servicers to find out how much they would charge you for the installation if that is the problem.
