Maytag gas dryer starts to heat but only fires for 5-20 seconds then cuts of flame. This is e repetative action indefinately. I have replaced high temp thermostat, thermal fuse, coils and even the timer. I retroublshot the H-T thermastat by connecting the leads together and running the dryer…it ran indefinately. I also checked with an ohm meter which showed continuity. Does this mean the gas valve is the problem, or maybe the thermostat is bad; even though its new? This may seem like a repetative post but I have done all of what has been suggested already with no luck…Please help.
Related topics
Maytag Gas dryer heating for only 6-7 sec's | 2 | 1162 | January 6, 2010 | |
Gas Dryer Irregular Heat | 0 | 1112 | September 24, 2011 | |
Maytag gas dryer not heating correctly | 2 | 740 | December 10, 2014 | |
Maytag gas dryer not drying | 11 | 26493 | August 23, 2011 | |
Maytag gas dryer will not heat | 6 | 3802 | June 20, 2013 |
