I received the replacement clock (control board) from appliancepartspro.com and have a question regarding installing it. My question pertains to the black jumper wire. Step #8 says if the jumper wire has a piggy back terminal (which mine does), the terminal needs to be removed. Step 10 says to crimp the 2 wires to the terminal included with the kit. Which 2 wires is it referring to? Do I simply cut the terminal (w/ piggy back) off of the jumper wire and crimp on the new connector (w/o piggy back). Then to reinstall do I plug the jumper wire onto the spade terminal labled "B*"?
Thanks.
