I changed both oven temperature sensors. I still get a F1-1 after about 10 minutes operating . When I cancel and shut the oven off, the stoves still beeps and shows the code. It seems that the fault code keeps showing after the cancellation. Subsequently the F3-1 code displays. I reinstalled the sensors and still get the codes. Is the the key pad the next item to replace. This is costly about $300…should pursue or look for some other problem… Thanks
Problem: Excessive frost buildup requiring weekly defrost
Main areas of frost build-up are at the ceiling and the underside of the
top shelf, along with the process tube.
There is no frost buildup under the middle (or the bottom) shelf.
Can this be repaired or do I retire the freezer and purchase another one?
i am a customer that received my kit but the instructions included were for a totally different part i need the instructions on how to install the seal. i have the agitator off and everything but dont know how to get the old seal off and the new one on.
Bulbs tested ok so now what’s my problem. I can here the switch go on and off either way by opening the doors and by using the light on/off on the control panel…HELP
did he just replace 1 of them? there are two of them back there, and there also is an idler pully wheel, that the belt wraps around. the best thing to do if you are going in there is to replace the 2 rollers, the idler pully , and the belt, and you will be good for another 7 or 8 years. the rollers are 12001541, the belt is 33002535, and the idler pully wheel is 33001783. take your time, and you can do it. tom %url%
Microwave quit heating again, last time it was a Vacuum tube. I took the Microwave down and took the cover off But cannot locate the tube. thought I would ask before I got any deeper.
Will A
I just recently cleaned this machine out and now it is not operating. It was working just fine. All of a sudden it was done. A small puddle of water was near the right side of the front of the machine. It appeared to have quit near the end of a cycle as there is still water in the machine.
When pushing the on button there is no response. No lights, no noise. NOthing. What might be the problem?
If it is the TCO, how can I be sure that this is the problem before ordering this expensive part?
