Hi,
I have a Maytag glas top cooking range and planning to replace one of the burned heating coils.
Can anyone advise me on how to open this glass top unit to replace the coil? There is no screws or any such devices seen externally…
Robin.
Hi,
Robin.
A model number may help others help you.
Hi,
The model No. is MER5751BAW
Thanksl,
Robin.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170784
This should help with the install
http://www.servicematters.com/maytag_library/docs/16026784.pdf
Thanks for your reply with the part No.
But I am unable to open the unit, since it is glass surfaced, where do in find the screws to take out the glass top?
The installation manual does not say anything about opening the glass surface.
Robin.
Take a look at Page 19.
Once the door is open there should be a couple screws holding the top.
I found it…
Many thanks…
— Begin quote from mathewrobin;282774
Robin.
