Maytag MVWC400XW4 Not spinning clothes dry
Hi everyone. A week ago or so I noticed that my clothes came out soaking wet. So I reran the cycle and noticed that it never agitated or spinned the clothes dry. It did pump out the excess water tho. I got the technician service manual and went through the manual test mode. The Lid lock worked. (Lid light went solid and I heard solenoid and I could not open lid) Gentle and Heavy agitation worked fine.
Now here is the confusing part. Sometime the Low and Heavy spin work. But most of the times the motor starts to spin then I heard a click and the Status LEDs for the cycle that I am on as well as the lid lock start flashing. The only way I can get back to the diagnostics mode is by pulling the power and reentering the manual test mode.
So I started working through the troubleshooting tests. Everything was fine until Test 3a Check 8. This was to test the shifter motor. When I was supposed to test the voltage I only got ~30 VAC when I was supposed to get 120VAC. The result of this test not presenting 120 VAC was to replace the main control board. I kept going through the testing and the next issue was at Check 11 for the Tachometer. I was not able to get a reading after entering the tachometer verification mode. The result of this test was to also replace the Main control.
So I got a replacement main control board. Whirlpool part # W10480274
According to this http://www.maytag.com/digitalassets/...0W10505982.pdf
So I put the new board in and same issue…
Any ideas what to try next?
I am confused because sometimes the Low and High spin cycle works. Usually not. I have checked all the connections and made sure that they were tight.
Thanks,
Shane
