Hello,
I’ve done some research and decided to replace my own bearings in my Maytag Neptune MAH7500.
When I took the unit apart, the rear bearing was completely disolved, except for the outer ring and the front bearing was cracked all the way through.
I used a 3 prong bearing puller to try and pull the front bearing out (note - soaked the bearing with unlock spray) and the inner part just came out, leaving the outer bearing part still in the unit.
Now I have both the front and rear bearing outer shell stuck! How do I get these out? The front bearing has about 2m gap and the rear bearing has zero gap.
Any thought’s or idea’s are appreciated.
