maytag neptune front loader leak
my washer leaks out the front door. i replaced the boot and the seal and it still leaks. Im wondering if it is overfilling and the pressure from the water is pushing out on the door allowing it to leak by. If so what do i do?
Remove the door and the front panel. Put the front panel aside and install the door back. Run the washer and watch where it’s leaking from. Post the results.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46669
You are welcome. I’m glad it was a simple fix.
