Maytag Neptune Makes Clicking Sound During Wash Cycle
Our Maytag Neptune makes a moderate, intermittent, clicking sound during the wash cycle. This problem seems worse with larger loads. Although the washer is old, it still works and cleans well and this noise is the only problem. I have read some information that suggests that this is a bearing problem, but not the usual "worn out" bearings. The information suggests that the noise is caused by the drum shifting forward and back axially during the wash cycle. There is a very inexpensive kit to remedy this problem, but I just want to verify what the problem is before I proceed. If the washer actually needs new bearings, I think we would just buy a new machine. Thanks for any help!
Check out [MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT + 12002535 WAX MOTOR](http://www.neptunebearing.com"]NEPTUNE BEARING[/URL] for bearings and a special tool kit created for the Neptune bearing job. The tool rental also includes the use of a DVD that shows step by step diasassembly, bearing replacement and seal kit installation.
MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT + 12002535 WAX MOTORHave you changed your door latch wax motor yet? Please see for details to prevent a control board failure. There is a video that explains the faulty door latch wax motor issue at [URL="http://www.neptunehelpsong.com).
