Maytag neptune problems
The washer fills and drains but it won’t spin or wash. The timer gets stuck at 1 minute remaining. The door switch is working.
What part mostly likely failed? The motor? The control board? A lose wire?
There are a couple of candidates here. Use this service manual to try and troubleshoot thing.
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Your model is discussed in detail at the back of the manual.
