Our washer would not start the other day. I checked the door switch and latch witch was replaced 6 months ago. Fine. Got the troubleshooting guide out and went through it with no troubles except that the start LED would not light. I finally got the start LED to light by puching some other button so it works. Got mad and took it apart and looked at the control board, couldn’t see anything bad. Put it back together tonight and it all lit up and it worked. Has anyone else had same problems?
Thanks for your post. It should help viewers who have this machine, and if they do they probably have similar problems.
