A small leak is coming from small holes in rear of outer tub near center shaft . What are the holes for? Two machined holes - one top one bottom. Lubrication ports? Is this a sign of a seal failing? Can hole be sealed temporarily?
Related topics
Maytag Neptune Washer Leak | 1 | 667 | October 28, 2014 | |
maytag neptune hole in tub? | 2 | 3134 | September 20, 2009 | |
maytag washer leaks | 3 | 1620 | December 8, 2011 | |
maytag neptune leaking | 1 | 1730 | January 3, 2013 | |
Washer leaking around tub base | 2 | 1606 | July 30, 2010 |
