Maytag not cleaning
I think that my dish washer is not putting out enuf pressure. Water sprays out of the spray arms, but they don’t spin. I have removed and cleaned the screen and filter. But no change. I am looking for a manual for teardown and trouble shooting. Since it drains fine impellers are probably ok. But I am not shure about any seals. Looking threw the parts manual here the seal has been updated. Now how to get to it? Any help is greatly appreciated.
thanx
Dustin
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDB7100AWB
Here is a service manual. Not the same as yours exactly but the pump looks the same.
http://www.servicematters.com/maytag_library/docs/16010622.pdf
Thanks the information help me find my problem. the discharge housing has a plate cast into the bottom. It broke off and was spinning around the housing slowing water flow till it wore a hole in the side of the housing causing pressure loss. I am ordering parts and should have a brand new 9 year old dishwasher.
Thanks Again,
Dustin
