Maytag oven wont work. Stove top works fine. Oven and broiler wont.
Is there a way to check for an error code or any common faults with these?
Thanks.
Thanks.
Hi.
Most likely you have the open hi-limit switch. It’s resettable and located at the rear of the range.Remove lower rear access panel to get to it. Use a multimeter to check switch for continuity. In case if it won’t reset get a new one
[part]74008715[/part]
Here are the breakdown diagrams and 01-Cabinet parts for Maytag MER5875RAF - AppliancePartsPros.com
Post the results.
Simon.
That worked!!! Awesome thanks!!! Second pizza cooking now lol
You are welcome.
Can I have a slice?
Simon.
