It was working fine as of last night. The stove (range) is flawless, the broiler is working the way it should. I have not tried to use it in cleaner mode. When I go to use the oven I do hear the thermostat click and then the temp will go no further than 100 degrees. Please help.:eek:
it is most likely your ignitor. it is easy to replace. the part # is 74007498. tom
