Maytag Oven WEIRD Error Code 5ab
— Begin quote from Gene;5691
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
Thank you very much for your simple, but perfect explanation. I had no idea what was going on, and I thought I broke the computer board or something.
:slight_smile:
Gene,
You saved the day! As an added bonus, I ended up cleaning the floor underneath after i pulled the stove to fumble around with the plug… lol
Worked on my Maytag.
Thanks !!
I have the same problem with a Frigidaire range. the Display will function, but won’t continuously show the time. I tried holding down the clock button for three seconds but it did not work. I looked in some manuals and it states to cancel the Sabbath function to hold the bake time and delay start for 3 seconds, but I do not have a delay start button. Any help is appreciated.
Bigun79
It would be best if you start your own post using Post New Topic.
Also include the model number.
You could look up the model number on the Frigidaire site to see if a manual is available.
