Maytag Oven WEIRD Error Code 5ab
I have gotten the strangest error code 5Ab on my Maytag Range display. My husband reset the time last Sunday (the 4th) for DLS(Daylight Savings Time) and last night this message code appeared. The top burners will light but the oven WILL NOT WORK.
Any help or advice would be greatly appreciated!
Thanks :slight_smile:
Thank You So Much!!! It Worked!!!
bought replacement oven therm. and it has three sets of dip switches instead of two like the oem part… double checked thru maytag and whirlpool and it all says the same part #…need schematic for this unit… wiring diagram or some expert advice…
It Worked Omg My Oven Has Been Out 4 Weeks Thank U So Much:) :slight_smile:
Bless you! I too, was trying to change for DST and started to cry when I thought I just broke my new stove! Now I can bake again!:):D:):D:):):smiley:
Dear Gene:
Thank you so much for your post on the 5ab maytag fix…
I was setting the time when it locked in the Sabath mode.:frowning:
I tried to shut stove down at breaker switch ,no luck then I was
in the process of fabricating a story to tell my wife ,:confused:
when I found your post.:smiley:
Ahh sweet peace… No lying … No nagging…:rolleyes:
Thank you again…
Coljpt
:cool:
I have the same issue and I’ve tried resetting the sabbath mode and it works for about 15 seconds and then returns to the sabbath mode without touching anything. Any suggestions?
Gene,
I held the Clock button for 3 seconds and then the Sab flashes for 5 seconds and stays constant with Sab displayed. After that It held the Clock button for 3 seconds and the Sab flashes for 5 seconds and returns to the clock display, but when I try hitting bake or any other button on the stove, nothing happens until I press the cancel button. Then I can hit the Bake, Clock or any other button and it works for about 15 seconds and then returns to the Sabbath mode automatically. I’ve tried everything it is instructing me to in the manual and still nothing works.
The oven I have is a Jenn-Air Gas Range Electronic Touch Control 800.
Thanks.
Ron
— Begin quote from coljpt;144961
Dear Gene:
Thank you again…
Coljpt
:cool:
Think LIke A MAN, and I did, and this post is like reading my mind.
Maytag 5ab :confused: :frowning: yes
breaker switch :cool: :mad: yes
fabricating a story :o yes
found this post :cool: Yes
Pushing the clock button 3 seconds fixed the problem :wink: Yes
Sweet peace, no lying, no nagging :smiley: Yes
Dollar signs of repair man gone :smiley: Yes
Thank God for this site :slight_smile: Yes
Thank You so much!! I tried everything i could think of!!You are a lifesaver!!
Mine has the same exact problem, for the same reason. Did anyone contact you, beside the person who said Jenn Aire? You clearly said it was a Maytag (like mine)…
Hello, and THANK you for the simple fix…for some reason nothing came up initially on the first post, and didn’t until after I asked my question. Duh.
Yes, it worked, and I am cookin’ again.
Eres un genio, desde mexico te doy las gracias!!!
You are welcome. Eres bienvenido.
Holding down the clock for 3 seconds worked for me too.
Gene, you saved my bacon also. I went shopping today and was going to buy a new range tomorrow. My range got about 2’ of water during Hurricane Ike. I had to replace the ignitor a couple of months ago and really didn’t want to spend any more money on this range. I thought my error code said 5 A6 or 5 Ab. Thanks!! Now if you can tell me how to fix my Frigidaire side by side that also got flooded. I actually feel pretty lucky to have had this work for 3 1/2 years after the flood.
— Begin quote from GalvestonBay;709356
…Now if you can tell me how to fix my Frigidaire side by side that also got flooded…
You are welcome. I’m glad that the problem with your range was that simple and you were able to fix it.
We’ll be more than glad to help you with your fridge. Just open a new thread in the refrigerator part of the forum with detailed description on the problem. Do not forget to post the complete model number of the fridge.
Gene… worked like a champ with my Maytag. Thanks a ton for the advice.
Thank you! Thank you! Thank you!! You’re a life saver Gene!
We’re glad to hear we could help you out. If there is anything else we can help you with, drop us a line.
