Maytag Panel shows 21
My control pannel shows 21 and won’t change unless I reset the power
Gene sometime it resets and works and sometime I have to leave it shut down for a while to get it to reset.
It will work as I said then sometime I have to leave it off for a while and then it will reset and work again
Gene said:
…What does it do at this point? Does it wash, drain or stays silent?..
I still need you to answer this question.
What does it do after you reset the power?
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170538
When I get it ti reset it works it does everything wash drain dry it totally works and every now and then it goes back to 21 and I have to reset it again and then it will work again totally for a while
Sounds very unusual. It can be a loose connection somewhere as well as a bad control board.
If it does it not very often I would keep use the dishwasher until it will die.
