Maytag Performa (pyet344ayw)
About 6 weeks ago the dryer would not power up at all. Per your advice, checked thermal fuse and it solved my problem.
I am now having the same issue, no power…I jumped the thermal fuse (only for a slit second) and the dryer powered up again. I have never had any problems with this dryer…what gives?
I am assuming that something is causing the dryer to blow this fuse…any suggestions?
Thanks!
