Maytag quiet series 100
this dishwasher won’t start. A couple of months ago it wouldn’t start, i took the inside panel off and put it back on, and it worked fine for a month or so. Nowit’s doing the same thing. i replaced the door handle assembly. still won’t run. Do you thin k it is the push buttoon/ control panel? I would appreciate a few suggestions before I drop another $60.
Any suggestions would be much appreciated.
rebel1222
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDBH950AWS
Here is the tech sheet
[http://www.servicematters.com/maytag_library/docs/16021814.pdf](http://www.servicematters.com/maytag_library/docs/16023222.pdf"]http://www.servicematters.com/maytag_library/docs/16023222.pdf[/URL]
Here is a manual
[URL="http://www.servicematters.com/maytag_library/docs/16021814.pdf)
I am assuming the unit is totally dead.
Sounds like you have a bad connection somewhere.
First remove power from the unit and check that the wire nuts connecting power to it are OK.
Next remove the doors inner panel and check that the wires from the control going under the unit are OK.
Check that the door switches are closing with a meter and that power is getting to the control board.
if OK.
Try the following cleaning procedure.
Check the control panel (keypad) with a meter. See the tech sheet.
If OK
Odds are the control board is shot.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
