Maytag Refridgerator not making ice
My Maytag does not make ice. I replaced the water inlet (there are two of them and I think I replaced the one that has a line for the ice maker and water dispenser not the one that connects to the water supply line) about 4 months ago. The water lines runs on the back of the fridge and it does not look to be frozen, The water in the door flows freely, the ice maker seems cold but I have not seen it run through a cycle with the wire moving up and down or even hear it making any noise. Can you tell me what to replace? There is no water in the ice cube maker, I’ve taken it out and looked so no water is getting there.
Hi
Switch around water valves solenoid plugs at both valves and press the water lever at the fountain(doors are closed).
If the ice maker fills up - replace the ice maker.
Check for frozen water inlet tube inside the freezer. If the tube is frozen replace the water valve 61005626
The ice maker D7824706Q
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47964
Thank you. Post the results.
Simon.
