Maytag Refrigerator Ice Maker Not Working. Please Help!
Good morning,
I have a maytag refrigerator model MFI12269VEM, SERIAL# 1031680NT
My ice maker is not working. I have tested the water inlet valve and one of the solenoids showed open circuit with my multimeter. I replaced the valve with a brand new part. The ice maker is still not working.
I switch the electrical connectors from the water dispenser solenoid to the ice maker solenoid, depress the water dispenser and water is going to the ice maker. However, I double checked that the original connector to the ice maker water inlet valve was secured as well. Ice maker still not working. I removed the ice maker, made sure the water fill tube has not be clogged with ice as well. Not sure where to go from here. Any suggestions may help. Thanks!
Please Help!
Thanks in advance.
Update: I removed the ice maker, thawed it out, cleaned it, thawed out the fill tube (I didn’t see any ice), thaw out the lines to the water inlet valve with a hairdryer… reinstalled and she’s working!
