maytag soap dispenser
Soap dispenser not opening during cycle…I have checked prior posts and replaced wax motor but door still won’t open. I opened it again and it seems that I can’t even open door while trying to manually push slide to left to release pin on the latch…slide seems worn…is this possible and can I replace just the slide or do I need the whole assembly?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=DWU8260BAX
Looks like you can get individual parts, take a look at section 06.
Thanks…took it all apart again & cleaned it up…think soap was causing problem…door now works but will get new parts & replace em…thanks for your help…
You are welcome
Glad to help out.
