maytag stack LSG7806AAE
my maytag washer will not fill or turn on on any setting for the different wash cycles. when i turn the knob to the rinse cycle it spins but no water. Spoke with a helpful tech and he said the pressure switch is likely bad. Are these the symptoms of a bad pressure switch? Any other opinions from techs? The fuse looks fine.
That’s a possibility, along with the control unit. and the water valve system.
Try replacing the pressure switch and see what happens. If you buy from this site you can return the part if it does not fix the problem.
