Maytag topload washer overflows
I have a Maytag LA612 topload washer that won’t stop filling for the initial wash cycle or the rinse cycle.
Tried hot only hot then using cold only and at various water level settings from small to extra large but still over would over fill before shutting off.
If I press the dial to pause the cycle and then restart the cycle, the water flow usually resumes but a few times the water remained off. If I advance the dial a few clicks while paused then restart the cycle the water always remains off.
Can you help me identify the problem part…I am guessing either the water level switch but possibly water level tube or the water valve.
Thanks!
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LA612
You have to do some troubleshooting to narrow it down as to the cause.
This switch is actually a pressure switch. It has a tube that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch’s set point then the switch activates turning off the water and starting the agitate.
Possible problems.
  1. Gunk blocking water from entering the tube. Remove the tube at the switch and blow into it to clear the plug.
  2. Cracks or holes in the tube allowing the air to escape. Inspect the tube. Also check that it is tight on the switch, if not, cut off half an inch and re-seat it.
  3. The switch is toast. Get a piece of tubing with the same internal diameter and attach this to the switch. Start a fill, then blow into the tube. You should be able to stop the water flow without blowing very hard.
    If you cannot stop it the switch is toast.
Note: I am assuming that you can stop the water flow by unplugging or turning off the unit. If this is the only way to stop it is to shut off the taps your water valve is shot.
