I have a maytag atlantis washer that will not stop filling with water. It will stop if I disconnect the hose from washer tub and blow through it,which I am assuming triggers the water level switch(it will click),then the washer will agitate,but once i stop blowing into the hose it will stop agitating and continue filling with water again. I just replaced the water level switch and tried again,same thing, fills with water,stops and agitates only when i blow through the hose. What else could cause this,besides the water level switch? Any help would be great! Thanks!
*Just as a side note this washer stopped working a month ago,would not spin or agitate,I replaced the pulley on the motor once I realized it was burnt up and broken,put on a new belt and it would spin and drain water,that is when I realized the filling problem…
