Maytag Washer Fills And Water Slows
My Maytag Centennial Top Load Washer Starts To Fill With Water For A Few Seconds And Then Slows To A Trickle Or Stops.if Youfil; By External Means When The Correct Water Level Is Reached The Washer Starts Help Please
Put a meter on the leads to the valve assembly when it is supposed to be filling. If it still is getting 120v when it stops, replace the valve assembly.
