maytag washer fills then stops
Washer fills with water then stops. If you lower the water level and turn it back on, it fills back to the correct level then stops. If you open the lid, the washer stops filling, when the lid is closed it continues to fill again. It doesnt mater which setting the washer is on, it does the same thing. I’ve checked other posts, it seems that the possibilities are the lid swich or the timer. I cant hear the timer running. Any help is much appreciated.
