Hello,
Not sure how old our washer is but I am pretty sure it was popular in the 1980’s, it came with our house. Anyway, we’ve had a few problems in the past that we were able to figure it out on our own, but this one is puzzling us.
Our washer will not drain, it will go through all of the cycles, and spin, but not drain. I have looked up what the problem could be from clogged pipes, our pipes are clean, on both ends, our pump works and spins, I watched it on the bottom, and the motor that helps it spin, is fine. I turned our washer on yesterday after draining and checking the pipes and it is still not draining. We even had a bowl under the pump and manualy turned it, and it just trickling out water. The belt looks a little loose too. Is it the pump or the belts, and if not what else could it be?? Any thoughts would be great! Thanks!
