The washer is working properly except for the spin cyle. All the water drains but clothes are still very wet. It’s as if the machine is not spinning the clothes fast enough or something. Help!
thank you:confused: :rolleyes: :mad:
Check and see if there is a partial obstruction in the drain hoses or pump.
If you need more info, please post a model number and the results of your inspection of the drain system and pump.
