Hello everyone,
The washer works fine most of the time but periodically the clothes are still too wet to be put into the dryer.
Hello everyone,
Replacing the thrust bearing, this part here
usually fixes a problem with spin on these models. When you take it apart make sure the pump is ok and that there is nothing blocking the drain lines from the tub.
Thank you Sid, I had checked and the water drains properly, the pump is fine so I will replace the thrust bearing.
Thank you again.
Great, let us know how it turns out.
