Maytag washer
I’m having a lot of trouble with this washer, filling with water at anylevel is not a problem and getting the water pumped out too,when it is in agitation cicle it makes gritty sounds sometimes so I decided to take a look under the cabinet and a noticed the trasmission making some slow movements as it wanted to move the tub at the same time that the machine was agitating as normal, also I could see the pulley, and the belt spining good and freely with no looseness as well, but when it went into the spin cicle I could noticed a low rpm and it was wobbleing too.I didn’t see any shavings in the floor but I could smell a burning plastic coming out from it.
I will apreciate any help
Lean the washer back against the wall, remove the belt and rotate the water pump pulley manually in both directions to see hoe freely it’s moving. Very possible the pump bearing has gone bad.
  • The part number for the water pump is AP4373022
Here are the break down diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=1345359&&model_id=5174150
