Maytag Washer
Hi Yes I Have A Maytag A5000 And We Just Changed A Fuse Switch , But Now The Cold Water Will Not Fill, Any Suggestions? What My Husband Did For Now Was Switch The Hoses So It Ony Washes On Cold Water, But All Of A Sudden It Does Not Rinse. Any Suggestions?
Well, it won’t rinse because it wants to fill the rinse water from the cold water valve which is not working.
You need to use a meter to see if power is getting to the cold water valve when it is supposed to be open. If so, replace the valve assembly.
