maytag washer
dont know how to get top off
how do i get the top off of this washer so i can get the part
Start by removing the door. Remove the hinge screws and the door will lift up and out. Remove the cover plates opposite the hinges. The front panel will now pull away from clips in the top corners, and pivot downward, to lift off the bottom clips.
Now look at the top corners exposed from the front panel removal, and you’ll see hooked brackets, each held in place by a 5/16" hex head screw. Remove these screws, and the hooks will pivot away to release the top.
Before raising the top, you’ll need to remove the four screws that keep the detergent and softener dispenser cup.
