Maytag Washer
Washer stopped mid cycle, full of clothes and water. Nothing wrong w/ timer. Suspect starting sw on motor. I took it apart and it probably needs replacing but I doubt if that is the answer. I can’t find the manual so I’m not sure if there are any other interlock switches other than the one on the lid which I have checked. The motor looks good, ie no burnt coils.
Any suggestions??
Check the lid switch and the fuse in their to be certain that is not the problem.
If it checks out, operate the machine with the cover off and try to see if the motor is getting current during the spin or agitation phase.
