I have noticed that my washing machine is now leaking water, and have determined it is coming from the back, bottom of the machine. I have checked all my hoses for any blockages and there are none. I was wondering how to trouble shoot this? Thank you guys all so much for you assistance in this! I really need clean clothes
Also - my dryer when drying seems to be making a very large banging noise. Its still effective in drying my clothes and maintains the heat. And the inside drum is still spinning. Is this a balancer issue? The make is a Whirlpool, Model # LE5650xmw0
THANKS AGAIN!
The washer probably has a bad pump. This is an easy fix. Remove the rear access panel and the drain hose and tub hose from the pump. Remove the belt from the pump. Take the 3 3/8th inch screws from the pump and replace that pump probably 30 bucks. The dryer like they say has probably got bad rollers probably 20 bucks or less. To get to them you must remove the filter and the 2 screws attached to the top where the filter goes in so that you can pop the spring clips and raise the top. Then remove the 2 screws holding the front and raise up the front slightly to get it out the way. Then remove the tub and inspect the rollers. You may find enough money to pay for both repairs. If them rollers are wore out then that machine has some age on it.
I Need To Replace The Most Inner Door Glass In My Oven. Kenmore 911.4654091. I Am Handy And Able. Just Need Some Directions.
Thanks Bob D.
