Maytag will not fill
The dishwasher was not filling everytime. I replaced the water inlet valve and the float switch. Still would not fill.
I pulled the door cover off and looked over the control board. I noticed a darkened (scorched area) so assumed (bad idea) that the board was the problem.
I replaced the circuit board and still not filling. I checked water coming from the water line, Ohm on the valve etc.
I have read that there is a diagnostic sheet under the kick plate but it appears mine is gone (I see a pouch where it used to be (had it worked on a few years ago). I did see how to enter the manual test mode and I did that but did not see anything that pointed to the problem. No error codes.
I am at a loss as to what I should check next. Is it possibile that I have a broken wire somewhere? Does anyone have the diagnostic sheet for this model?
Good job. We are glad you were able to fix it.
will spin and dry with very light load (2or3 light items)
I did not get your model to come up, but assuming this is a standard direct drive top loading washer the likely problem is the clutch.
This site will show you how to work on it.
http://repair2000.com/wp_clutch.htm
