I have replaced the igniter which it needed and then it would heat but not hold the temp so I replaced the sensor however it still will not hold temp it is set to. It heats to selected temp then drops off dramatically before trying to get back to selected temp.
If you replaced the ignitor, and the sensor, the only thing it can be is the clock control board. The part number is 74008105.
