IMy handle was loose at the bottom of the handle. I am attempting to replace it. I opened the door and there is only a screw at the top, which I unscrewed. The handle then came completely away from the door. There is still a piece of broken plastic inside the bottom hole. It just spins around but will not come out. Is there something I should know regarding removing it, or do I just need to get a pair of pliers and force it out?? Thank you.
Related topics
Microwave Handle replacement | 1 | 1494 | May 28, 2009 | |
Microwave Handle replacement | 1 | 2720 | April 10, 2010 | |
Microwave Handle Replacement, yet again. | 2 | 3914 | January 17, 2010 | |
Need Help installing Microwave handle | 0 | 826 | May 28, 2009 | |
replacing handle on GE microwave | 1 | 1194 | June 27, 2009 |
