Need some detail on how to install replacement light bulb in microwave oven
— Begin quote from Roes;267370
Roes,
I take for granted, you mean the oven cavity light, not the cooktop lights.
Here is the part number and the instructions from the service manual.
Good Luck,
[part]AP4057187[/part]
[LEFT][FONT=Helvetica-Bold][COLOR=#231f20]Grille[/COLOR][/FONT][FONT=Helvetica-Bold][COLOR=#231f20]
[/COLOR][/FONT][SIZE=2][FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20]The top full-width grille is removable for service to some[/SIZE]
[SIZE=2]components, such as: humidity sensor, oven light, door[/SIZE]
[SIZE=2]removal, flame sensor, vent motor capacitor, fuse,[/SIZE]
[SIZE=2]control panel, and stirrer motor (some models).[/SIZE]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=2][FONT=Helvetica-Bold][SIZE=2][COLOR=#231f20][FONT=Helvetica-Bold][SIZE=2][COLOR=#231f20]Grille Removal[/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Helvetica-Bold][SIZE=2][COLOR=#231f20][FONT=Helvetica-Bold][SIZE=2][COLOR=#231f20]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=2][FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20]1. Disconnect power to oven.[/SIZE]
[SIZE=2]2. Remove screws located in front on top of microwave[/SIZE][/LEFT]
[SIZE=2]securing grille[/SIZE]
[LEFT][SIZE=2][FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20]3. Pull outward on the top portion of the grille releasing[/SIZE]
[SIZE=2]the tabs.[/SIZE][/LEFT]
[SIZE=2]4. Reassemble in reverse order.[/SIZE]
[LEFT][SIZE=2][FONT=Helvetica-Bold][COLOR=#231f20][FONT=Helvetica-Bold][COLOR=#231f20]Light Socket[/COLOR][/FONT][/COLOR][/FONT][/SIZE][FONT=Helvetica][COLOR=#231f20][FONT=Helvetica-Bold][COLOR=#231f20]
[/COLOR][/FONT][SIZE=2][SIZE=2][FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20]1. Disconnect power to oven.[/SIZE]
[SIZE=2]2. Remove Grille (see "Grille" procedure).[/SIZE]
[SIZE=2]3. Remove screws securing bulb holder.[/SIZE]
[SIZE=2]4. Remove light bulb and socket.[/SIZE]
[SIZE=2]5. Disconnect wire terminal plug.[/SIZE][/LEFT]
[SIZE=2]6. Replace and reassemble in reverse order[/SIZE]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/SIZE][/COLOR][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/FONT][/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT]
