Turntable will not turn when glass turntable is installed. Basically the turntable turns with no weight, but with weight it only clicks. Any advice would be much appreciated, don’t want to replace more than I have to.
The turntable had not worked for sometime, read you forum ordered the part for a turntable motor on 7/05/10 recived it today 7/08/10 and as easy as one two three, well maybe four and five was in there to thank you.
