Hello,
Have GE model PSS25MGMA and is freezing everything on fresh food side. Need to know where thermostat is and a good place to buy one from. ( If problem is thermostat.
Help Will Be Very Appreciated.
Thank You
John
Hello,
Thank You
John
I would sugest to check the cold control first. Sounds like it is bad. Parts can be ordered from this website
PSS25MGMAWW --GE Profile Arctic side by side frige ???
I was told to replace the thermostat def.
I would like to know how to get at it …the diagram on the site does not seem to match the fridge.
I have the same issue - milk is ice and the ice maker and water do not work anymore.
I bought it in 2001
Can anyone help me ???
thanks
There are two separate problems with your refrigerator - temperature in the refrigerator and the water/ice dispenser. I would recommend the damper control and the main control board together.
The part number for the damper control is [AP3950129](http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3775595&&model_id=219573&diagram_id=571428"]AP3775595[/URL]
The part number for the main control board is [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3950129&&model_id=219573&diagram_id=572525)
Here are the break down diagrams for the GE refrigerator http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=560752&&model_id=219573
When I look up the part on AppliancePartsPros using the part number for the Damper Control that Gene gave you, it looks like it includes directions on how to modify it for different units.
Perhaps you can zoom in on the directions and get some useful info off of it.
I have inherited this older GE PSS25MGMA frige. It was freezing food, and yes the damper door was broken. (don’t understand how it got broken, there’s nothing in there to cause it to jamb.)
Anyway, took it apart and epoxy the door back together. Verified that it is working properly. Re-installed.
HOWEVER, the fridge side is still freezing (20*).
What else could be the issue? Mother Board?
