:rolleyes: My mixer will only work in high speed. What part do I need to replace?
— Begin quote from tblackw;423993
Tblack,
There are 2 possibilities,based on your description,
A broken Control Plate Spring
[part]AP2930085[/part]
and or a bad Motor Phase Control Assembly
[part]AP3177667[/part]
You’ll have to remove the end cover plate from the back of the mixer "head" and the side trim plate screws to access the phase control and the spring, after you raise the upper housing from the lower housing by removing the screws holding the assembly together.
Good Luck,
How do you repair these parts?
I meant replace this parts?
Any instructions?
— Begin quote from tblackw;426487
Any instructions?
The manual is not a PDF file, I can’t attach it to a response.
If you can send me a fax number, I’ll be happy to send you the appropriate information, to assist you.
— Begin quote from Joe / APP Team;426581
Fax:706-428-8617
Need instructions on how to replacing the phase control board on my Kitchaid Mixer, Model K45SSWH.
