Sorry for the long first post, but I wanted to give all the info I have. If anyone can help me figure out what to do next, I’d really appreciate it.
We have a GE Monogram ZIS480 built in side-by-side fridge/freezer. Within the last couple of days we noticed that the freezer was running a lot but wasn’t staying as cold as it should. The fridge is set at 37 degrees, and the freezer is set at zero. The fridge stays at 37, but the freezer is presently at 23. That’s cold enough to freeze water, but some of the other things in there aren’t frozen as solid as they normally would be.
I’ve checked several things, including:
Compressor seems to be running (and since fridge is cold, I presume it is).
Compressor fan is running.
I can’t see the evaporator fan, but it appears to be running, as I can feel plenty of air moving through the vents in front of the evaporator.
The evaporator coil ices up after a while. It looks like a complete sheet of ice across the whole coil, though I have not taken the freezer apart enough to see the entire coil yet. I’m just looking at the part I can see through the vents in front of it (by sticking my phone in there and snapping a photo).
I’ve tried defrosting the evaporator with a hair dryer, but that doesn’t solve it. (It does defrost it, but it still doesn’t get cold enough).
I’ve checked that the freezer isn’t overloaded and vents aren’t blocked (I only see one vent at the bottom right of the freezer and it isn’t blocked).
Today I got ahold of a service reference for it and checked the resistance of the defrost heater (38.5 ohms vs expected of 37), and the four thermistors. The thermistors read as follows:
Fresh food 1 & 2: 14 kOhms at 37 degrees.
Freezer thermistor: 18 kOhms at 23 degrees
Evaporator thermistor: 19 kOhms at 23 degrees.
The thermistor reference chart shows 10 kOhms at 50 degrees, 16.3 kOhms at 32, and 27.6 kOhms at 14.
I’m not really sure how to interpret the thermistor ranges – the values I read on mine all fall within the ranges of the next higher and lower temperatures on the reference chart. So does that mean they’re good?
Has anyone seen this scenario before (cold fridge, warm freezer)? What should I check next?
